QUOTE(ernestj911@gmail.com @ Jan 10 2013, 10:11 AM)
this one is really cool.
Click to view attachmentI have the same spoiler on my flared car. I Cropped off an inch from the bottom and flared it.
In order to do this, I mounted the spoiler to the car and Gorilla glued some EPS foam to the area I wanted to flare. I use EPS because I have a lot of extra and I can cut it with a hot wire.
I used the flared fender as a guide to cut, sand and shape the foam. If you use EPS foam you will need to use epoxy resin. Polyester resin will eat EPS.
If you go to a Michaels or some art or flower shop they may have something that I think is polyurethane foam. Rigid polyurethane foam can be used with polyester resin. I have also seen people use spray foam but it's a bit soft and not so easy to shape.
What I am thing of is green or white and has big open cells that may need to be filled with body filler before you glass over it.
Be sure you sand and clean any surface you want the resin to bond to.
Good luck.
Mike
