My son came over last night to get me to help remove some really stuck oil gallery plugs in his 04 sti heads. He had broken a ezout in one trying to get it out. I have a bluepoint kit that you drill a hole through the plug and then drive a splined shaft into the center and then put a hexogonal sleeve over it that you put a wrench on to remove the plug, broken stud or whatever. this doesn't put as much spread on the broken or stripped part so it is easier to remove. I used them in industrial maintenance.
While we were working I brought up the romraider deal and he reminded me that he wasn't using rr anymore because the main guy from rr now works for cobb. The guy at cobb will support only the cobb customers. Soooo he thinks the best way to get the best programming on stock ecu's is now through cobb. It's about 500.00 and it's a piggyback, but he thinks it's worth it if you are using speed density which seems to be the best way to go for a hotrodded motor. I told him the quickest way was to me the link or other brand of standalones. I remember just changing the air filter and the length of the intake track on his sti was not a easy thing to do as the maf got confused. The first complication was the new at the time drive by wire throttle body. His motor has so many mods it's a good thing he is a me or he probably would need to pay a tuner to handle it. For the motors that do not use cam control romraider is probably ok, I think. The 04 sti uses a 32 bit speed ecu and the 02 wrx uses a 16 bit speed ecu which als makes the wrx easier to work with he says. I think all the newer subys may use cam advance and retard control and drive by wire since about 05.
I thought everyone into subys might be interested in his opinion on romraider for the later motors if you are planning on improving their performance.
I was hoping I could rely on him for my tuning but I bet I will need to know it all as I'm never satisfied with anything as being the best it can be.
