QUOTE(Nine_14 @ Jan 7 2013, 08:09 AM)
Don't forget there must be a plastic foil behind the door panel.
Although here we'd call it a plastic sheet vapor barrier behind the inner door panel & over the inner frame.
That styrofoam was a DAPO add-on, cuz that will only hold moisture to aid tin worm!
Porsche/VW did inject foam in other body cavities in an ill advised attempt to both sound deaden & waterproof the bodies, which instead turned out to cause water-poof!
