QUOTE(si2t3m @ May 16 2003, 12:27 PM)
I wouldn't go wider than 245 on 9's. It might look good with something wider, but you will loose on handling.
now wait a minute. you say 225x7 feels good (which i second!) and then you say don't go wider as 245 on a 9" ...
where are the 8" in your calculation?
245 seems like a very good fit for a 8" (which is what i'm gonna run in the front),
so what would be wrong with 285 on 9" ???
9 x 2.54 = 22.86 centimeters
285 x 9 = 28.5 cm on a 22.86 cm rim = 1.25 ratio
245 x 8 = 24.5 cm on a 20.32 cm rim = 1.21 ratio
225 x 7 = 22.5 cm on a 17.78 cm rim = 1.27 ratio
sooooo, the 285 x 9 is even a slightly "better" fit than the 225 x 7
Andy
