I have the side shift transmission on my 72 with all factory hardware. It is hard to pull into first gear. The linkage joint at the firewall is nearly to the firewall just when it drops into first gear. I tried removing some stroke from the sleeve adjustment up by the shift lever but that does not help since the linkage at the firewall is already bottoming out so to speak. I am wondering about pushing the rear link at the transmission forward on the the shifting rod and drilling a second hole in the rod for the locking bolt to land in. This would in effect push the lower, 1st, 3rd, and 5th gears towards the center of the shifting pattern.
Any thoughts?
James
