QUOTE(ruby914 @ Aug 14 2013, 04:13 PM)
Kent,
I love the casters idea
When I get back to working on my car, I was going to look into a support attached from the tranny to the firewall. Maybe you can pave the way.
Sorry I'm late getting back with you guy's. Hey Mike
, you do realize that you are one of the MAIN reasons I got into this. Not sure whether to
you or
you, yet.
Just kidding. I did take a quick look at that and the first ? that came to mind is why? It is only about 2" aft of the engine mounts so it isn't to add support when the tranny is out?? Given the bolt thru it was horizontal I doubt it was for torsional control?? Was it there to spread the weight load? If it were attached to the trunk wall what reinforcements would be needed?? Your thoughts?
QUOTE(jsconst @ Aug 14 2013, 07:35 PM)
Nice engine cradle, the wheel setup is brilliant
Definitely have to copy that design when I get ready to build mine.
You guys are way ahead of me....I'm still trying to get my shop done so I can get started.
Nice job Kent, keep the details coming.
Jeff
Hey thx Jeff. You might want to go .125" wall if you go DOM. BTW, that was one 10' piece of tube. I cut it a little close as I had 2.5" left over when finished! Next time I won't cut it as close as it took too much effort (you know, that double and triple checking your measurements
). I could have used a little more cushion when constructing it.
So I better post something up so I don't have to call myself out on "The Slackers Thread". I really don't have
to show as I have been trudging thru this maelstrom known as a wiring harness.
There aren't enough joint's in the world to take the edge of this job. So I
with it until I begin to feel my sanity slipping away then move onto something trivial. Or should I say something less demanding? Simple suits me well.
So as a diversion I'm falling back to something else. This is one of those items. The slave (is that politically correct?) cylinder needed another 5/8" clearance so....
Click to view attachmentClick to view attachmentA flat panel would have made things a bit easier. This cover will need to be removeable to inspect/service the banjo fitting.
Click to view attachmentClick to view attachmentAnd as it turns out the starter needs a bit of room also. Even after I asked Bob which one would clear I still end up with a clearance issue. The good thing is if it takes a
I won't have to worry about another one fitting if it happens in BFE. And before I get flamed for the elongated access remember that the engine/tranny combo is up and then slid forward, so it is necessary.
Click to view attachmentRather than pontificate I'll just run some pic's past ya and you can use yer imagination or ask a question if ya have 'em.
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentThis littl POS consumed 4 hr's of my day, after all was said and done. I couldn't be any slower if I tried. I had to go over it twice to fill any pin holes as I didn't want this piece rusting out soon.
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentAfter all that I ended up with this gap which I corrected with a tab welded in place. I'll show that in the next few days. It's primed, in place and already covered up as the trunk is converted back to the cat motel. Yea the little bastards sleep in the trunk but they do their business outside and whilst me neighbors have rodents we have none.
So after a few more stints in the wiring asylum I soon found another item that required my attention (just don't make me go back to wireworld. BTW, I stole this idea from Bob (bigkat). I had laid out what I thought to be the correct location for the pump assembly then a little voice said better double check that so I went thru the threads and noticed that Bob had his centered a bit more than mine. I had fixated upon installing it upon a flat surface and almost ruined a good tank. After looking at Bob's install it occurred to me that the criteria was where the pick up is located! DUH
This is why you will see one drawing imposed upon another. The piece of wood held in place by the cleco side clamps is there to position the compass upon. By looking straight down the filler neck w/ a plumb bob I established the location of the reservoirs rim. By sticking a tape inside the reservoir I determined the diameter. Rather than bisecting a segment in the circle to locate center I just split the compass and worked off the edge of the circle. Once I felt OK about my location it was just a matter of figuring the offset in the pump itself and flipping the pickup sock 180'. I'll need to build a step onto the base of the cover to accommodate the offset on the tanks surface but that's another day.
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentand the $$$ shot
