QUOTE(rick 918-S @ Nov 23 2013, 08:30 PM)
Nice Kent! What is the HP of that 6? I'm working on an idea for a mid-engine shop truck and was thinking a Sub 6 would be the answer. I would need enough hp to pull a trailer. (my trailer with a 914 on it)
IIRC, 230hp Rick. The 3.3's are cheaper, longer, heavier and have a few more horses. If you go 2004 or newer you'll be "fly by wire", +30 hp, ACAV. Gets complicated.
QUOTE(euro911 @ Nov 23 2013, 08:58 PM)
Industrious bugger, ain't ya?
Looks nice. Neat 'wheelie bar' too
You know, not really. This was the easiest mod I've done to this car, yet! As pristine as my '76's shifter is....it is a turd compared to this cable set up.
Click to view attachmentQUOTE(DBCooper @ Nov 23 2013, 09:11 PM)
I'm happy you were able to get it worked out, since I still can't get down on the ground. Well, I could get down but probably not back up. At the end of the day it's pretty simple, isn't it? It makes all the difference in the world in how the car drives.
I need to take some photos of the way my shifters mounted, it's a little different than your setup. Well done.
Well thank you DB. Emulation being the sincerest form of flattery.
Or more bluntly; I copied from your build.
I didn't have that curved piece and was too lazy to make one. I tried to closely align the cable with travel path of the push rod in the tranny to lessen the cable force. Other than that I stole from your post. Hey DB, do you have back up lights? I noticed that you have the back up and neutral senders looped together. And yes, it is pretty simple in the end. I couldn't wait to rant here about how well it shifted, How precise and crisp it feels. Then I remembered you had already said what I felt.
You did not exaggerate.
