QUOTE(CptTripps @ Feb 27 2014, 01:42 AM)
Outstanding progress. One quick question though:
Which bed liner did you end up using? That's on my list, and I don't want to use what I used last time.
Monstaliner. I think it came from JEGS. I traded my "flucks" core welder to my buddy for 2 gallons of this stuff. JEGS gave it to him because they shipped the wrong colour. Win Win. I think this stuff needs to go on thick if you want durability. I did this in the front trunk area for obvious reasons. The pans were just a couple of coats. It will be covered and didn't need to be tough.
QUOTE(Chris H. @ Feb 27 2014, 09:24 AM)
I'm re-thinking what size pipe to run under the car too...was going with 1 1/4 as well but if that isn't necessary I'll go smaller. Much easier to bend the smaller it is (insert easy joke response here....).
Chris and other concerned souls: this comes from the horse's, or in this case the KAT's, mouth. Bob (BIGKAT83) was kind enough to share his set up. He is running SS braided lines w/ AN fittings but other than the material choice, the sizes are the same. As I said somewhere back; I don't expect the hose size will be a problem. And if there is a cooling problem I will suspect my choice of routing and additional turns that I added. Bob also twinned the 1.25 into a 3/4 line. This setup has served his 3.3 and 3.0 engines. Just be sure both 1.25 hoses are identical in every respect. IOW, the T should be in the middle and if one side goes 8" turns 90 degrees then 5" the other side should be the same. Helps to balance the flow.
Great progress Kent! BTW guys can you coat the inside of that copper with anything that would keep it from reacting/breaking down into the water? Or slow it down enough to make it less of an issue?
QUOTE(AfricanHijinx @ Feb 27 2014, 10:03 AM)
what bed liner did you use? I used some duplicolor stuff from the FLAPS and it was garbage it scratched pretty quick
Hijinx, see above. Capt tripps had the same ???
QUOTE(ruby914 @ Feb 27 2014, 10:35 AM)
QUOTE(skeates @ Feb 27 2014, 08:45 AM)
QUOTE(76-914 @ Feb 26 2014, 05:27 PM)
I think it was Skeates who mentioned he was tired of playing Concentration with himself when describing the wiring.
Very well put.
Twas not I who coined that one, but I'll take the credit.
Looks like you are making some good progress. I'm particularly interested in seeing how your cooling solution works out as it is much easier to run those smaller diameter hoses. I also went with the 1.25" hose to keep things close to the stock sizes, but it sounds like there may be a significant amount of wiggle room there. Keep up this momentum and you'll be driving before you know it!
I think that was Scott Amenson on his MIA 2014 come back.
I still have $200 worth of copper that I pulled out of my car. Going to make a wind chime.
I had mine all suspended by rubber. Thought I could get around it. I think it was Porsharu that sent me this PDF? May have saved my butt.
I didn't want all my work rotting from within.
That's not the article I was looking for. It's better. Thanks. I think with that info I can avoid loosing a radiator. Hell, it may all come out and go beneath the car like everyone else.
Radiator new was <$60 so it wouldn't hair lip me if it tanked. I love that the article tells how to test it with your VOM. Did you perform all those tests? Results?? It points out why grounds are so important. The OG Suby harness must have 20 random ground cables that attach to the body in different locations. Hmmmmmmmm.
Hey, hey> My fan switch arrived so I can plug that hole in the radiator.
