Bare with me. I've reached that point of going back to "complete" items that an organized individual would have already completed. Some of these shots you've seen before. To quote Oat Willie, "Onward thru the Fog!". A free bowl of Chile if you know who he was.
Put some SS hardware to good use here
Click to view attachmentClick to view attachmentApplied lables indicating all my ground points for the next poor schmuck.
Click to view attachmentNeeded to modify my "K n N" filter to accept the air temp sensor.
Click to view attachmentClick to view attachmentClick to view attachmentWhen you've reached the torque value but need another little bit to align the cotter pin, this is it! Smooth as butter and requires no strength.
It's also fast as Hell to remove them this way. If your close and need break yours loose, come on by. I've got pipe wrenches up to 60".
Click to view attachmentClick to view attachmentMeet the "new" Hell Hole. If your doing one of these hydraulic conversions you know what I'm talking about. It's a bitch fitting that clevis, spacer and cotter pin. And if you've done it more than once you feel my pain.
I'm good with the outcome, though. The large fender washer between the floorboard and return spring, compresses the rubber washer against the floorboard for an air tight seal. Didn't plan that, just fell in my lap.
The bolt access hole above it still needs a snap in cover.
Click to view attachmentClick to view attachmentI hope that I didn't jump the gun and throw this Dynamat in too early. I'm going to try it w/o any on the firewall, first. If it's noisy I'll add some but I don't have an air cooled engine w/ carbs so I should be alright.
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentShort of paint and removing the white plastic cups for a "return air", the rear trunk is a "wrap". The one harness laying in the right rear corner is for the 3rd or rear 02 sensor. This may get 86'd. From what I'm reading this does not effect the tune and is basically there as "reporting device" used when it is smogged; which it won't be! Also, I 86'd the 2 covers I made for the starter and clutch slave and replaced them with one large black metal box which I made . As it turned out the clearances weren't large enough (in my mind) with the 2 individual covers. This will give me a service access for future repairs, too! As it sits, the roof will still fit in the trunk!
Click to view attachmentClick to view attachmentNext up.......... a foolish attempt to design and construct an exhaust system. It will be aluminized steel rather than SS. Many reasons for now and I may go SS later when I learn to weld SS.
