It's been a few months since my last post. The car now has about 2700 miles and most of that has been uneventful, which is a good thing.
Items have been a rear brake line that leaked because I forgot to tighten it. That took 7 months to show up. The right headlamp power plug became disconnected because I ran the lead incorrectly and it would pull off when the lamp rotated. The horn took on a life of it's own till I discovered the warped rubber puck under the horn button. And one chaffed radiator hose that I carelessly installed.
This weekend at Rt66 the temp went up on me at 2700 ASL and I had to pull over for a few minutes then continued on with out incident. I caught it early and the engine didn't get heat soaked. I had been hammering it! OAT was increasing in Palm Springs. I had the RPM's in the 4-5K range and was pumping water too quickly thru my single pass radiator. Climbed another 3500' that day w/o incident but I kept the power setting at a sane level.
What I learned from this is that I'm "Border Line" on my cooling. I need a 2 or 3 core radiator. I plan on adding A/C and want to be able to drive in the summer, thru Vegas with A/C blasting. So, I will document that here once I install another radiator.
Mike Wills was nice enough to bring a windshield to Rt66 from AZ, Thx again Mike.
So yesterday afternoon I removed my old sandblasted windshield. I was afraid of running into rust issues with < than a month before WCR15 but decided to just go for it and was pleasantly surprised. A surface rust area the size of a dime on the lower right corner and a slightly larger area on the left lower corner but it too is just surface rust. I Ice Picked the Hell out of it. All of the holes for the plastic rivets are true and no rust on any of them.
I need to get a roll of Butyl Tape, a seal for the dash to windshield, clean and prime the channel then slap it in.
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentCheck out the dirt. No wonder they hold moisture in this area.
Click to view attachment The old seal removed. The shit was so hard a cat couldn't scratch it!
Click to view attachmentL&R lower corners. This is a bad as it gets.
Click to view attachmentClick to view attachmentThese 2 pic's show the general condition of the channel. I'm a lucky man.
I won't bore anyone with the install. That ones been done already.
