QUOTE(Chris H. @ Aug 27 2015, 08:47 AM)
What does this guy think he is...a plumber or something?
Kent what are you going to control the setup with? The stock Subaru controls? Can't remember. Looking good
The controls are mounted on the under dash unit I am using. I wanted to use Vintage Air's Gen2 Mini system but it is 1/2"nom too tall to fit beneath the cowling. If using that model I would have used their adapters to convert the OEM controls while in there. Very simple believe it or not. And I would have used that model if the car were completely apart. Then I could do some cutting and welding to make it fit. Another evaporator that caught my eye is a cheap $60 Chinese unit
http://www.ebay.com/itm/Universal-Under-Dash-AC-Air-Conditioner-Add-On-Unit-12V-8-5A-3-Speed-UN-0888C-/351494122081?hash=item51d6aeaa61&vxp=mtr that has 4ea. - 2.25" openings. 2 for the OEM dash vents and 2 for the defrost. No way to isolate them so it would always blow thru all 4 but that is not a problem unless you like foggy windscreens.
The challenge is that the unit is 12" deep which doesn't leave any wiggle room and you can't lay the unit on it's back to aim those outlets upwards.
I think it is doable but I'm concerned about the units longevity as well.
This is the unit I will use. Heating and cooling!
http://www.ebay.com/itm/130609850519?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT I will need to trim a tad bit off of the console to fit. A bit more on the right side than left. But take a close look at the pic and you can see the 2 openings on top for the defrost. Those openings end up dead center beneath the defrost vents so that will be convenient.
Look for many screw ups along the way. You remember my fiasco with the gages.
QUOTE(JRust @ Aug 27 2015, 12:08 PM)
I was just considering running the lines through the long on the passenger side. Good to see that coming together Kent! I need to get mine going. Was hoping to have it done for Red Rocks. Doubtful with it off for paint now. I'll get it back less than a week before I leave. So I will probably just finish my center console & deal with the a/c over the winter
Jamie, you can run behind the valance on either side or in the long. And the std barrier hose would fit w/o kinking. Just make sure it is the same side as the AC connections on your evaporator. I still need to run some water lines for the heater. I may run them up the tunnel or use the drivers side valance. They won't put off any heat unless I am using the heat. Then it becomes a moot point. GM has a nice 4 port heater valve. It's vacuum actuated so you need a vacuum solenoid as well. About $50 for the both of them.
