I was able to button it up this week; several times.
Sorting out gremlins and making things fit.
The defroster actually blows. I thought it was pretty good then noticed it was on low. Yeah, it works. I did manage to
a few hours away chasing what I presumed was a vacuum leak only to discover that I needed to turn the blower on before it would energize the vacuum solenoid to the heater valve.
I found that I have the lines to the heater crossed at the by pass valve but it will just have to stay that way until after the G&R meet manana.
Here's a pic of the footrest after a little grooving for the hose. Since I completed the freon connections at the condenser I was able to finally run the condensate drain. Previously I wasn't sure what would end up where and yadi, yadi. It exits almost in the corner. Off 'bout 1".
Click to view attachmentHere is why. I wanted to place it exactly in the corner but found the jack point piece would be compromised. To miss drilling thru the meat of that piece meant moving appx 1.5" further away from the corner or................drilling the hole dead center of the cone. The piece will push up when the jack point is used too.
Click to view attachmentTrimmed the speaker pod to fit. It wasn't primo before and it damn sure ain't now but it tidies the area up once in place.
Click to view attachmentClick to view attachmentClick to view attachmentI punched a hole in my new carpet (thx Mikey) for the condensate drain.
Sacrifices were inevitable.
Click to view attachmentJust a few pics of the inside after everything was back together. This coming week I should be able to charge and freeze. I hope, I hope, I hope. So many things to go wrong.
I can see the light at the end of the tunnel getting brighter.
Click to view attachmentClick to view attachmentClick to view attachmentThe left panel ended up getting a trim where the new duct crosses over.
