QUOTE(last337 @ Jan 10 2013, 08:23 AM)
So last night was the first time I used my STE to sync my new 40s. I was pleased to find that all the carbs were initially pulling just about the same vacuum. However, when I went to make fine tuning adjustments with the air bleeds to sync each stack to the highest pulling carb I had no success. Am I correct in assuming that you would back out that screw to bring up the vacuum on the lowest pulling carb? That didnt work. I even backed out the screw on the highest pulling carb to see what would happen and nothing. What am I missing here?
Regardless I got them all relatively close and idling well but then had problems once I snapped linkage back together. The idle jumped up as one of the linkage arms was holding one carb off the stop (go figure).
Anyways, I would really like to figure out how to do the fine tuning with the air bleeds. Another thing I was confused about was the mixture screw adjustment. I started about 5 half turns out and then began to slowly turn in all the way. On some barrels I didnt notice a difference until the screw was almost seated. Usually once it was seated it would start to stumble then I could back it about 1/2 turn and it would stabilize. Based on this link I am still within range on my jets. Although, I must admit it is tough to distinguish when it is actually stumbling on some barrels.
I feel like even though this is a somewhat simple (when described) procedure, there is a significant learning curve to it, especially when it comes to tuning mixture screws by ear. I plan to try again this weekend but any help anyone can provide on air bleed adjustment and mixture screw adjustment before then is appreciated.
Kevin (rhodyguy) has been my Obi-wan through my carb tuning and he has taught me several key things. Hopefully these help you.
1) First, make sure you have valves adjusted to spec as this can have big effects on the amount of air/fuel that each cylinder pulls.
3) Then, make sure that both carbs rest on the idle screws when you are trying to get the mixture settings right, linkage off. If not, its possible the throttle shaft is twisted which can cause big headaches.
4) The bypass screws only have an effect on the idle circuit, so if the car is idling high you may tuning them accurately. You're looking for an idle somewhere between 700-900 rpms, the lower, the better.
4) Adjust the mixture screws first, the bypass screws second. Once mixture is set, you can go back and fine tune the bypass screws, then recheck the mixture screws.
5) It sounds like your idle jets are almost on the big side for your application. 1/2 turn out is not a lot of room to play with.
6) Hex bar linkages are to put it mildly, awful. I learned the hard way that there are a number of configurations of air cleaner bases, bar lengths, down rods, etc and if you don't get the right combo, you'll never keep the carbs in sync. It sucks to learn this after the fact because you've already spent the money, but please seriously consider a cable-style linkage like the one Chris at Tangerine Racing produces. It will make your life much easier. Trust me. It sounds like you have a similar situation with what I had where you feel like everything is set at idle, but as soon as the bar rotates, the geometry is not the same side-to-side. You might have the right setup with the correct geometry, but need to adjust the length of the downrods, or where the "arms" attach on the hex bar laterally. More than likely you'll just get frustrated at which point, again, consider the cable linkage.
7) Oh yeah, buy the Tomlinson's Weber Tech manual. It will improve your quality of life when owning a carburated car.
-George
