rhodyguy
Jan 10 2013, 02:58 PM
with all the carb talk these days i thought i'd share a dif way to run your fuel lines.
these are the appropriate sized fuel lines compatible with our modern fuels. from the tee to cross over to the other carb i used 2 rubber isolated camps thru the holes in the rear upright tin. i split a piece of vac line, wrapped the fuel line in the vac line and it fits perfectly in the groove in the engine side of the tin. the holes in the tin serve double duty. i put another set of clamps on the rear of the tin on the same bolts to keep the hot starter wire secure and and off the trans. while the clamps hold the hose/wire securely it doesn't pinch anywhere.
i think this method helps with fuel temps keeping the fuel line as far away from the engine heat and no direct contact with any metal while securing it. lmn what you all think.
k
7TPorsh
Jan 10 2013, 03:29 PM
I brought mine up top on the backside to a tee then into the carbs. I was worried about the fuel heating up around the tin.
last337
Jan 10 2013, 03:59 PM
i have mine coming up from under battery to a tee then splitting to each carb with one line going across under engine compartment cover. I am a bit worried that having the tee so much closer to one carb will affect the fuel flow to each carb but I guess I will know more if I cant get them balanced correctly.
rhodyguy
Jan 10 2013, 05:37 PM
by cover you mean the lid?
aircooledtechguy
Jan 10 2013, 08:29 PM
[quote name='last337' date='Jan 10 2013, 01:59 PM' post='1800098']
The "T" can be anywhere between the two carbs. your fuel pump will ensure that both carbs get all the fuel they need.
last337
Jan 11 2013, 01:55 PM
QUOTE(rhodyguy @ Jan 10 2013, 05:37 PM)
Yes, I mean the 'lid'
