QUOTE(Spoke @ Jan 14 2013, 01:00 PM)
See the attached schematic for the turnsignal circuit in the 914.
If all lights flash when the hazard switch is pulled, then lamps and most of the wiring is ok. This leaves the wire to the steering column and/or the turnsignal stalk itself.
Try to find the BK/WH (black/white?) wire going from the hazard switch to the steering column and look for bad wires or connections. Hopefully its the wires and not the turnsignal stalk.
This was a lot of help. Was able to determine it was the signal switch on the column. Lucky for me i have an extra parts car and made the switch. My turn signals are now working.
Thanks for everyone on the help.
