QUOTE(Eric_Shea @ Jan 16 2013, 07:23 AM)
6's are the same except... the spline count. (odd... same issue with the front torsion bars).
So, to keep a 6 stockish you would simply need to find a pair of standard 914 axles for these.
Again, the CV's are identical in size etc.
Mark's right though. With a 3.2 I'd look for a 108mm setup with Sway-a-Way axles.
One thing not mentioned so far in this nor Mark's other topic on these CVs, is that Porsche (& VW) could've spec'ed different strengths of steel for these parts, based on the expected stresses from the respective engines' power & torque output.
This is the same thing we see every day with bolts used in different applications, where some are high strength & others not.
Perhaps - just perhaps - the steel used in one part is differentiated by non-compatible splines, threads, etc. - so that someone doesn't get them mixed up. I'm not saying this is necessarily the case on what Eric is suggesting, but it might be & is worth looking into further before swapping parts.
The T-1 VW motors turned out much less power than the t-4, & the H-6's in turn put out more than T-4s, etc. While you may not have a catastrophic failure in your CVs/axles if using a different one, you may get far less life out of the parts.
I have the OE 914 CVs in my 73 914-2.0 which had 14 years & 172k of not easy use with nary a problem (before she got whacked & put up in my garage).
Whereas, others I know personally who had used T-1 CVs as more economical replacements back in the `70's-80's after track damage to their originals, & they typically got 1/4 - 1/2 the life out of T-1 CVs vs. OE 914 CVs.
So I'm suggesting those using T-1 in 914 or 914 in 911/914-6 to go in with open eyes that there may be other differences in the materials used which are not visible to the naked eye, a set of calipers, etc.
This is the same sort of thing we've had "heated discussions" with general contractors for years who try to cut corners - & add to their profits - by ordering structural steel, bolts/nuts & other connectors is lesser grades of steel, and then arguing that "it's the same size as [you] spec'd" - but it's not the same grade of steel as our structural engineer spec'd! I've seen this happen for over 43 years now!
Ergo, when my Porsche mechanic of similarl 40-50 years of experience in 914s & other Porsches, VWs, etc. - I do trust his judgement & wealth of knowledge when he tells me that the Type IV CVs are stronger than Type I CVs. I don't know his opinion on 911 axles & torsion bars, but would certainly check them out down to the rating of steel &/or other materials used before assuming a swap would be straight across equivalent.
