type11969
Nov 10 2004, 08:24 PM
Well I've looked through the archives about pedal boards because I keep on hearing about them, I understand their purpose, my question is, did all 914s come with them? Mine doesn't have one, thus the confusion. I did drive my car without a problem though, so are pedal boards necessary?
Does anyone have some pictures of stock pedal boards and pictures of the pedal cluster underneath? I'm curious to see what else might be missing or different from what the pedal cluster should be like.
Thanks,
Chris
seanery
Nov 10 2004, 08:28 PM
all the cars should have them, they have the pedal stops.
here's one of engman's installed in a car:
ppickerell
Nov 10 2004, 08:29 PM
I will make billet pedal boards for $1000 each. You will gain 100 HP, your bald spot will start growing hair and you will get laid more often o r in some cases the first time. But seriously pedal boards are laser cut pieces of aluminum that your pedals mount to that have bling but have no performance enhancing aspect that I can detect. If your pedal board is broken, then by all means order a cool looking aluminum one. Do chicks really assess one's pedal board status prior to making mating decisions?
Joe Bob
Nov 10 2004, 08:30 PM
They help with proper pedal throw....lack of a board can allow pedals to go to far and screw up the master cylinder, and clutch....not as critcal for the gas....
They are available from PP and if you can get a wooden one..you can make an aluminum copy easily....
seanery
and how to get one:
Pedal Board Info
Nov 10 2004, 10:16 PM
QUOTE(type11969 @ Nov 10 2004, 07:24 PM)
without the pedal stops on the board, you're setting yourself up for failure ...
broken clutch tube!, broken clutch cable, broken accel. cable, broken brake MC ...
you get the idea.
Andy
type11969
Nov 11 2004, 06:40 AM
Ahh, I see. Since my car isn't going anywhere for quite some time, I guess I don't have to worry about not having a pedal board for a while.
Anyone have any pics of a pedal cluster sans pedal board?
machina
Nov 11 2004, 07:07 AM
yah,
type11969
Nov 11 2004, 07:39 AM
cool, thanks!
Britain Smith
Nov 11 2004, 11:25 AM
This is from a 911, but its all the same...
type11969
Nov 11 2004, 11:58 AM
Britain (or anyone for that matter)-
How does the gas pedal fit into the scheme of things? I know it attached to that link arm, but does it also attach to the floor pan? Anyone have any pictures of that?
Thanks,
Chris
PS - Thanks for that pic Britain
Nov 11 2004, 12:04 PM
QUOTE(type11969 @ Nov 11 2004, 10:58 AM)
yes, it does ...
it's bolted onto the floorpan just in front of the pedal-cluster ...
Andy
brant
Nov 11 2004, 03:08 PM
I want to add a picture late (just because I am excited to own a camera finally)...
type11969
Nov 11 2004, 03:22 PM
I . . . can't . . . see . . . the . . . keyboard . . . that . . . picture . . . is . . . too . . . bright!
Thanks for the pic Brant, and nice choice of colors, that is the stock color of my 914, and I hope to return it that way (someday).
brant
Nov 11 2004, 03:30 PM
it is a little bit bright...
ha...
brant
