michaelmoo
Nov 11 2004, 09:10 AM
Does anyone have the measurements or a picture reference on the factory placement of the rear emblems?
Jamie
Nov 11 2004, 09:24 AM
Rear emblems for original 73 1.7 as measured: Y=42mm,X1=55mm, X2=38mm
tod914
Nov 11 2004, 09:29 AM
michael,
Do you plan on drilling holes? Give Sean a holler, maybe he can make up some vinal ones for you.
Root_Werks
Nov 11 2004, 09:43 AM
I made my own from a sheet of black vinyl. The look great and you can make whatever you want out of them. Exmp: Mine say 914-6 2.2 and they look like something the factory would do. I don't have a plotter or anything so it took me an hour to cut the numbers out.
michaelmoo
Nov 11 2004, 10:07 AM
Thanks.
I dont plan on drilling. I have a crazy idea of taking my orignials and making a mold of them. This way they will not have the pegs and will be flush on the back. I will be able to use 3M emblem tape that most manufactures use and not have to drill!!
Hi_Fi_Guy
Nov 11 2004, 10:17 AM
QUOTE(michaelmoo @ Nov 11 2004, 08:07 AM)
Thanks.
Due to my deadline I ended up using vinyl but had similar thoughts to what you are doing. I think it will look great. Best of luck and post some pics when you are done so we can see your handywork on these.
Root_Werks
Nov 11 2004, 10:19 AM
That is a cool idea. It would be neat to have numbers molded in black plastic so people could put together thier own emblems. Just sell numbers.
914-8 5.7
914-6 2.7
914-4 2.2
Or whatever. The ebmlems would look factory.
So when can we expect a production run of these?
michaelmoo
Nov 11 2004, 10:29 AM
lets see how they turn out first!!!!!!!
SLITS
Nov 11 2004, 10:45 AM
QUOTE(michaelmoo @ Nov 11 2004, 09:07 AM)
Thanks.
There are enough of them around with the tabs broken off - you can find them!!!
tod914
Nov 11 2004, 10:47 AM
How about cutting off the tabs and filling it resin?
michaelmoo
Nov 11 2004, 10:53 AM
Thought of that, but I won't get to make a big mess like when I make molds!!
If I make the mold I can at least make more to "play" with if/when I mess them up.
Bottom line is that I dont want to drill!! Spent to much time on the body to drill holes in it.
