Not that it matters, but .........
Single relief cases have 8 mm galleries
Dual relief cases have 10 mm galleries.
The first valve is the oil pressure relief valve and is located at the pump end of the case. It controls passages leading from the oil pump to the oil cooler, oil gallery and sump return. This is to avoid cold oil from rupturing the oil cooler as the cooler is bypassed by bleed to the sump.
When oil is warm, the first valve closes and pressure is regulated to the galleries via the second control valve at the flywheel end. When experiencing excessive pressure, the valve opens and bypasses the excess pressure to the sump. The first valve closing routes the oil through the oil cooler.
Spring pressures are set at 42 psig, 30 wt oil at 70 C (158F), 2500 RPM. Wear limit is 28 psig.
Loaded length of 1st control springs on Type 4s is 1 9/16" (39 mm). Load @ length is 15.0 - 19.4 lb
Loaded length of 2nd control spring on Type 4s is 1 1/16" (26.00) Load @ length is 3.8 - 4.4 lb.
Thank Tom Wilson for the information ....................
And, Why would you want to control oil pressure? Running excessive pressure to the bearings will pit them (remove what used to be called babbit material).
