QUOTE(EJP914 @ Jan 19 2013, 06:49 AM)
I put new 195/60x15 tires on 5 1/2" Fuchs to replace the original Michelin 165 x15's.
Do I run the same tire preessure as before; 30lbs rear and 27lbs front? I have this amount of air in the tires now but they look "flat". Since the tire size has increased, does the amount air have to increase too??? What inflation pressure do most of you use?
Thanks for the help.
Unfortunately, every tire and wheel combination is slightly different. Starting at 27/30 is probably a good idea and a good baseline. Ultimately where they belong is determined by tire wear ( bald in the center, pressure too high ) ,ride quality ( are you getting beat to death ( too much pressure ) ? and does the car handle the way you want it to ( turns in to corners well etc. ) . Going up or down 2 psi can make a big difference to a sensitive driver who knows his car. Too much pressure...near the max inflation pressure marked on the tire, will give you a harsh ride, poor handling and wear in the center of the tire, but isn't dangerous. Too little pressure ( below 20 psi ) can cause excessive heat in the tire and lead to catastrophic failure. 27/30 sounds good to me .
