QUOTE(last337 @ Jan 20 2013, 05:06 PM)
QUOTE(JawjaPorsche @ Jan 20 2013, 03:58 PM)
QUOTE(last337 @ Jan 20 2013, 04:46 PM)
I changed oil the other night and after finding a very loose oil filter I thought that the oil leak previously dripping from filter was fixed. Today I warmed up the engine more than the last few days only to find the same oil leak after the engine warmed up. I checked filter and everything looks tight. It seems oil is collecting on the top rim of the filter on the passenger side of the engine. I am unable to see a source of oil leaking above almost like its coming from the filter itself. I really think its oil cooler seals but could it be coming from filter? The mating surface bw filter gasket is really small. Any help troubleshooting is appreciated before I tackle seals.
Are you sure it is not leaking from one of the push rod seals? There are eight seals and they leak over time. The newer seals are much better than the original seals. I had mine replaced last year and it solved my leak(s)!
How can I check those? Is it something I can do with engine in car?
By the way, it only leaks when car is running
Get some brake cleaner and spray where the leak is coming from and clean and wipe. That way you can trace the leak better.
Replacing the push rod seals involves pulling your valve cover, lifters, rods, pulling push rods tubes, cleaning everything, replace seals, and reinstall everything. You will have to have valves readjusted. This is not a simple job! There may be good discussion on a previous thread.
Without a lift, this is not a fun job!
