So I tried starting the engine for the first time since it was rebuilt to a 2056lt. Before being rebuilt, the car was in storage for 20 yrs. I already went thru the car replacing everything from hoses, fuel pump, shocks.....even the kitchen sink! So the engine will turn and only start for a bit when we spray gas down the TB. It sounds like it struggling to fire up like a diesel. Fuel delivery is good (new Bosch fuel pump), coil connections are good, grounds are good n tight. I am using a Pertronix system and a Msd Blaster coil. Only reason I have a blaster coil is because I plan on connecting a 6A Msd sytem after it starts and is timed in. My question is/are:
Am I doing wrong to use the blaster without the Msd system?
Here in Mo it has been well below 32 degress while tring to start the engine, shouldnt the cold start injector start to work? How can I tell if its working?
Any ideas what I maybe missing to make it fire up on its own?
I'm planning on checking fuel pressure tomorrow. Anything else?
Thanks for your help. Im open to the idea of anyone coming to help. Im in the Warrensburg KC area.
2.0 (2056} lt EFI all original
