There are too many to post at once. I'll post pictures for items as they are requested.
I cleaned the side shift transmission & rear valance, everything is in "as-received/as-removed" condition.
I will only check the site once or twice a day. If you want a faster response, send me a PM as I seem to get those more quickly.
Prices do not include shipping. Shipping costs are extra.
If you know of a good way to ship items economically, tell me. If you have a preference, tell me. Do not assume I know. I use USPS or UPS Store.
Items marked (PITA to ship), mean I lose a lot of time to package and (or drive 20 miles to) ship and is somewhat compensated in price.
Many of the "excellent" parts were removed from a 1972, 1.7, from Ohio that was parked in ("Mom's") garage since 1979 when the Hell hole rotted.
Balance of parts were from the four 914's it took to make one.
Evaporation Tank, 1972 (excellent - slightly dirty not crusty) $50
Steering column assy, 1972 (no ignition switch) $50
Tan Driver side Pocket & PS armrest, 1974 (driver condition)
Dash facade - backetweave, 1972 (excellent)
Odometer reset cable assembly, complete $15
Fuel tank filler, 1972, (very good exterior, but rusted under gas cap from very stale fuel)
Headlight motors, 1972, $40 pair
Air cleaners, oil bath, 1970-1972, $40 (PITA to ship)
Front air dam, fiberglass, P/P Products (two small cracks from parking too far forward) $90 (PITA to ship)
Airduct, Defrost assembly, 1972 (complete, excellent) $100
Airduct, Defrost control, 1972, (nice) $35
Rain tray drain tubes (one broken ear, no other cracks) $20
Front license plate brackets (may not be for 914) $5 each
Door straps (prevent door from over-extending (one good, one very-good/excellent) $20 pair
Door latch mechanisms, 1972 (no rust, not worn out), $40 pair
Door Passenger, 1972, solid, straight (surface rust removed & treated) $125 (PITA to ship)
Rubber intake elbow between air cleaner & throttle, from 1.7 1972, $5 each
Roll bar Pad, 1972, (minor cracking by two screw holes, nice daily driver quality), $40 (PITA to ship)
1.7 Intake manifold with Temperature sensor, cold start injector, Aux air valve, throttle, TPS, $85
Intake mounting bracket for 1.7, 1972 (holds air cleaner on case), $10
1.7 Intake manifold with temperature sensor, cold start injector, Aux air valve, $60
Throttle with Throttle Position Sensor, from 1.7, 1972 (1 of 2) $25
Throttle with Throttle Position Sensor, from 1.7, 1972 (2 of 2) $25
Aux air valve (believe it is for 2.0L as is same as a 2.0L Type-IV bus) $35
Glove box, 1972 (excellent, no holes, no rot, minor wear) $25
Glove box door with basket weave, 1972 (excellent) $25
Monza muffler for 1.7, 1.8, upright muffler, $50 (PITA to ship)
Monza muffler for 1.7, 1.8, horizontal muffler, $50 (PITA to ship)
Rear trunk release solenoid, $30
Rear trunk spring loaded latch, (excellent) $5
Motor mount for Side shift configuration, with attach point for the engine, $100 (PITA to ship)
Side shift, transmission (leaks at speedometer drive seal/o-ring) $350 (PITA to ship)
Side shift, shifting rod aft of firewall, $25
Side shift, gear shift with knob, $40
Side shift, connector between shifting rod and transmission linkage $20
Targa Hold down point and hook for front of Targa top $10
Targa top $35 (PITA to ship)
Rear trunk lid (one good w/o rust $40, one driver w/rust - free) Pick up only - Ann Arbor, Michigan, 48108
Front trunk lid - $10 Pick up only - Ann Arbor, Michigan 48108
Jack hold down straps, $10
Rear glass (1 of 2) (no defrost wires, boxed, ready to go) $20
Rear glass (2 of 2) (no defrost wires, loose, pickup only) $5
PS window regulator, early style, $15 (PITA to ship)
Knee pads, 1972, (very good/excellent with metal strips) $50 each (PITA to ship)
