Elliot Cannon
Jan 22 2013, 08:17 PM
Starting to put my five lug conversion back together and discovered I have two different wheel hubs. I didn't realize just how different till I started installing them. The one on the left has subtle differences. It is almost 1/4 of an inch smaller at the outer flange diameter. The wheel lug holes are the correct bolt pattern but are closer to the outer edge of the hub flange. The not so subtle difference is, when installed, it sits in too far and rubs... badly. To make things worse, I bought them so long ago, I don't even remember who I bought them from.
Looks like maybe a trip up to Parts Heaven. I wonder now, if I can tap the hub out without damaging my new wheel bearing? I know. I know. I should have checked them more carefully. Sheesh! You guys are starting to sound like my wife.
TargaToy
Jan 22 2013, 08:21 PM
Are the back sides of the flanges different? ie: does one of them have beefed up reinforced areas behind the stud holes?
Mike Bellis
Jan 22 2013, 08:28 PM
Too bad your timing isn't better. I drive near PH every day AND I'm heading to King City (Fort Hunter Liggett) tomorrow. BTW. I'm usually down at FHL once a week...
draganc
Jan 22 2013, 08:29 PM
That sucks! I think you will have to replace the bearing also.
Good luck,
Dragan
Mike Bellis
Jan 22 2013, 08:30 PM
BTW, I'll be heading back to FHL 1-28-13 if I can help you with delivery.
Elliot Cannon
Jan 22 2013, 08:40 PM
QUOTE(kg6dxn @ Jan 22 2013, 06:30 PM)
Thanks Mike. I'll let you know.
Elliot Cannon
Jan 22 2013, 08:48 PM
QUOTE(TargaToy @ Jan 22 2013, 06:21 PM)
Actually both do. I'll have take the other one out tomorrow and take a really close look at them. (Something I should have done anyway). Then I guess I'll order two new wheel bearings. Faauuck!! It takes considerable effort to get the hubs out and I don't know if I want to trust the bearings after beating on them like that.
McMark
Jan 22 2013, 11:17 PM
Doesn't the bearing retainer keep everything in place? I use a slide hammer to pop the hub out in one quick motion.
Elliot Cannon
Jan 22 2013, 11:26 PM
QUOTE(McMark @ Jan 22 2013, 09:17 PM)
I do basically the same thing except I drive it out with a punch from the other end not unlike the description in the Haynes manual. Either way you do it, it places a side impact on the bearings that they were not (I think) designed to take. If I'm wrong about that and the experts agree that the bearings can be re-used after banging on them like that, I'm all for it. I just installed new ones and would rather not have to buy two more but I'd hate to get it all back together and have one or both fail because they were damaged driving out the hubs. Has anyone had experience where they banged out the hubs, yet still re-used the wheel bearings? Am I being overly cautious?
Krieger
Jan 23 2013, 12:15 AM
I've done it twice. I do not know about the bearing itself, but the seals get mangled.
McMark
Jan 23 2013, 12:26 AM
I have to do it tomorrow. I'll take a video for you.
euro911
Jan 23 2013, 01:48 AM
I've only removed a set of rear hubs once to date. I had to beat the the hell out of them with several rests stops before they finally came out. Needless to say, the bearings were toast afterwards, however they were originals from 1971
Now, if you had a nice shop press ...
I wonder if stuffing the hubs with dry ice would shrink them enough to allow you to remove them without damaging the bearings?
sean_v8_914
Jan 23 2013, 08:53 AM
i have saved parts for years thinking I had "the goods". ...until I went to use them.
I feel your pain
Elliot Cannon
Jan 23 2013, 12:40 PM
QUOTE(euro911 @ Jan 22 2013, 11:48 PM)
A shop press won't work to remove the hubs without putting huge stress on the bearings. The bad hub actually came out relatively easy so maybe the bearing is OK. Yeah right!
lagunero
Jan 26 2013, 12:23 AM
THOMAS says Hi
euro911
Jan 26 2013, 01:14 AM
Tell him to get his butt back on the board
Elliot Cannon
Jan 26 2013, 12:26 PM
QUOTE(lagunero @ Jan 25 2013, 10:23 PM)
THOMAS says Hi
Did he forget how to email?
Elliot Cannon
Jan 26 2013, 12:50 PM
Two more steps forward. Rear suspension done, 72mm wheel lugs installed. Waiting for rear rotors and front brakes. I sent Jeff at QRS pictures of the problems fitting up the fiberglass fenders. He sent me a message today saying, "it's a simple problem but difficult to explain".
Possible one step back.
Elliot Cannon
Jan 28 2013, 08:13 PM
Just got the rear rotors. Still working to get the left rear fender fit up. Drilled some holes and "clecko'd" it today.
