Hi all,
I am the ecstatic new owner of a slightly neglected 1973 914, 1.7 model which someone has put a 2.0 in.
I got the car with first gear problems and ended up having to take apart the tranny and replace the first gear synchro and dogteeth... which I did myself successfully with out terrible difficulty. I got to Drive this sweet little thing around for about a week and the engine sputtered and died on me.
It doesn't get gas
-replaced the fuel pump
-replaced the filter
still no avail
The leads in the fuel pump plug read a laughable .2 volts when the ignition is on and the engine turned over.
Im not getting the power
-replaced relay
-cleaned all connections on the regulator plate
Im getting 12 volts across the leads attached to the relay, but the relay isnt closing my circuit.
Any Ideas??
I miss driving the darn thing!
