I finally got an older dizzy with the vacuum advance today to replace the uh oh 9 that came on the sucker. One thing that wasnt good, when I pulled the other dizzy out it didnt even have an o-ring on it so I know that couldnt have been good although it didnt appear to leak oil too bad from under the distributor.
Anyways, before pulling the dizzy I had in there I made a mark of where the rotor was relative to the tdc mark. Upon installing dizzy with the vac advance I notice that the tdc mark is in a much different location than before. I assume that it doesnt matter where that mark falls as long as I can confirm by looking at fan that the location is indeed tdc? Currently it seems to fall maybe around 9 o'clock if noon was the front of the car. For the mark on the new dizzy to fall where it did before there would be no way for the vacuum to fit.
So I installed it the way it fit and tried to rotate it so the rotor was in roughly the same position as before relative to the tdc mark. This also changed my plug wire orientation relative to the cap so I adjusted those to 1 being on top of tdc mark and then proceeding clockwise 1-4-3-2
I attempted to start and after a few cranks I get a sputter then a terrible sounding backfire. Is my timing just off or did I do something else wrong?
