76-914
Jan 27 2013, 10:00 AM
Like the title says I need some 16ga steel for some body repairs and I don't know where or what to buy. Do I buy a sheet of hot rolled galv or plain steel. I'd like something that will hold up to the weather. Also, where to buy. Patton's sells 4 x 8 sheets but that's a little more than I need. TIA. kent
wndsnd
Jan 27 2013, 10:06 AM
I bought mine from a local sheet metal guy. He is a provider to HVAC Service guys. I used 18Ga and 16ga scraps they had around the yard. I would say, "I could use a 2 X 2 and they would go out and see what they had. This way it was 1/4 the price of haveing full sheets cut.
Also, don't worry about surface rust, you need to clean all with a die grinder or something before welding and it all will be nice and shiny then. Or, clean and spray with a good weldable primer and you are good to go or store till you need.
John
SLITS
Jan 27 2013, 10:25 AM
K&H Metals on Main St in Riverside. They have a scrap remanent pile of sheet metal or did when I bought 18 ga to repair /6 HEs.
strawman
Jan 27 2013, 11:05 AM
Don't weld galvanized steel unless you use a fresh air supply! Burning galvanizing compounds are highly toxic. You'll need to treat the welds anyway, so just use hot-rolled sheet metal. I use Metal-Prep first, then two-part epoxy primer.
76-914
Jan 27 2013, 12:23 PM
Thx, just the answers I needed. I've heard of welders with galv poisoning and drinking milk.
Elliot Cannon
Jan 27 2013, 12:45 PM
QUOTE(76-914 @ Jan 27 2013, 10:23 AM)
Drinking milk causes galv poisoning? It's a good thing I don't eat any dairy products.
Spoke
Jan 27 2013, 12:50 PM
My steel supply here in Allentown is Hill Metal on, yep, you guessed it, on Hill Street.
Great little steel shop with lots of stock. I've bought 14, 16, 18, and 20 ga steel sheets from him. They usually have many bits and pieces laying around.
He has several car guys that call on him for steel. He always asks me about my 914 when I go there.
gothspeed
Jan 27 2013, 01:35 PM
'Industrial Metal Supply' in Irvine, Near John Wayne Airport. They have everything you need, even small pieces. All for very good prices.
edwin
Jan 27 2013, 04:32 PM
Hot rolled vs cold rolled?
I thought cold was the go for strength
Edwin
RON S.
Jan 27 2013, 06:35 PM
We live in the age of the internet now.
almost anything is available and can be shipped to your door.
www.onlinemetals.com
no minumims, and any size shape and grade of material available...
There are all kinds of online metal vendors now. The above is just one source...
76-914
Jan 27 2013, 07:55 PM
Yep, found Bobco Metals online and ordered tonite. $15 shpg is cheaper than gas.
