More goodies that I no longer need. This set-up is built around the Bugpack 3 stage pump that I modified by adding an extra scavenge port to work with the stock outlet port in the case(the BP pump came with a single outlet for the two scavenge stages).
3 stages each with 30mm gears.
I custom built a fan hub extension and motor mount bracket with clearance for the AN fittings. The steel mount bracket bolts directly to the case with no mods needed. It also bolts to the stock cross member with no mods.
The entire system worked great with zero issues.
The pump body is scuffed up pretty badly where it goes into the case as a result of a heavy handed extraction (don't ask!LOL). Could be cleaned up with emory paper and leaks would not be an issue as it is a scavenge stage so any oil caught in between the case and the pump housing would get sucked in by the gears.
It comes with O.E. valve covers with -8an fittings welded for the second scavenge stage.
Many hours went into making the custom parts.
$55.00 + shipping for everything
Click to view attachment Click to view attachment
