QUOTE(jmargush @ Jan 27 2013, 05:30 PM)
I have a question concerning setting deck height.
Do you first need to know what the cc of your combustion chamber is so you can work back to what you want for compression ratio which in turn will establish your deck height?
or what is the proper process to follow?
Yes, you have to know the combustion chamber volume--then you decide your target Compression ratio, then enter that into the calculator like the one on CB performance (http://www.cbperformance.com/v/enginecalc.html) to find the deck height.
Buy two or three sets of shims and carefully deburr them and then measure them--I've found wide variation within a pack of shims and had to combine from two packs. Put it all together and use some clay on top of the piston to check for valve clearance--enjoy!
