I'm not looking to make a killing on these parts, i'd rather know they have good homes and will be put to use.
I would like to recoupe at least a decent portion of my money on the pistons, as they were bought new when i planned to build a 1910 but i also understand that no one will pay new price for them here, so i'll take a hit and pass them on to someone who can use them. smile.gif
I make special mention about cleaning up the crank and rods and miking them, but that goes for any of the parts that you might want checked out.
Take a look and dont be afraid to ask!
EDIT: Payment via paypal please
The List:
Assorted valvetrain, Probably enough to put together one
good set of rockers not sure if there is a full set of 1.7L rockers in there but I can check $50-OBo
Side shift rear linkage bar and rear coupler, I also have an extra coupler around that has fairly new bushings installed (i cut the shift rod for my new linkage) $15-OBO
Airbox for fuel injection, I've never owned a 914 with fuel injection so i dont know much about it, i believe it came from a 1.7 or a 2L
so its probably d-jet. $10-OBO
Factory Oil-coolers, I have 3 them, I'd like to sell two (providing they dont leak, which i will test before i ask for any payment or ship them out) $25 each-OBO
Two factory camshafts, slight wear on both. If anyone wants a bolt on gear i can cut the rivets and
spotface the gear (my last build has over 26K on a cam gear this way so i guess it works) $10 as is, $25 spotfaced
1.7L crank, it still has rods on in the picture because they came out of the case im going to build a 2056 in. I'll take the rods off,
clean everything up, polish the crank and mic it if anyone is interested, I wont let someone buy a basket case unless they really want to smile.gif $100-OBO
1.7L rods, same as with the crank, i can clean them and mic the wrist pin bushings, etc $40-OBO
type 4 oil pump (definitely one of these, possibly two) $10-OBO
upper steering shaft out of an early car i think...just pay shipping rounded up to the nearest whole number
2 factory flywheels, pressure plates, and clutches.$50-OBO per set
side shift front coupler (bolts to shift lever) $5
3 914 distributors, 1 chrome 009. $25-OBO each
various heater duct work and engine cooling tin, I dont know the specifics, but if you can find a picture of what you need, ill check the stash.
and for a little extra i'll sandblast it and powdercoat (provided it fits in my oven) $5 a piece as is, $15 a batch for powdercoating
Lots and lots of little parts and tiny hardware, the pictures show the top layer of stuff.
