QUOTE(bandjoey @ Jan 28 2013, 03:15 PM)
My rear wheel bearings hi-low squeal is getting loud enough I think it's time to replace them. From looking over threads, and the PMB videos, it doesn't look possible without taking the swing arm off the car.
I don't find anything here with removal/installation info and without doing a new alignment.
CAn you give me the in's and out's of removing the swing arm and reinstalling it later. How do I mark and relocate the shims to keep the alignment the same?
Appreciate the help!
It's not hard to do it on the car.
1 While still on the ground, remove the rear hub caps. Remove the large axle nut on each side. Jack up car. Secure on Jackstands.
2 Remove wheels, brake calipers, discs and axles.
3 Drive out the stub axles using a socket with an OD slightly smaller than the bearing ID.
4 Remove the bearing retainers.
5 Drive out the bearings using a socket slightly smaller than the bearing OD.
6 Clean, derust and debur the the bearing cavity. Coat with antisieze compound.
7 PULL new bearing into hub using socket used in step 5 against the outer race only. Do not put any pressure on the bearing except on the outer race. Rig a puller with 1/2" threaded rod, nuts, washers plates. Some imagination is needed here.
8 Reinstall the bearing retainer plate.
9 PULL hub into bearing using a socket the size of the bearing inner race. Do not put any pressure on the bearing except on the inner race.
11 Install wheel hub nuts, tighten as much as you can for now.
12 Reinstall axles, discs, calipers and wheels.
13 Put car on ground. Torque the wheel hub nuts to spec, reinstall cotter pins. Torque wheels, reinstall the hub caps, go for a drive.
