Elliot Cannon
Jan 30 2013, 04:56 PM
Can I MIG weld on the car with the engine installed? The only thing electronic is the pointless distributor. Do I disconnect anything besides the battery? Does the gas tank have to be removed?
76-914
Jan 30 2013, 05:10 PM
disconnect the battery leave the fuel cell in.
Elliot Cannon
Jan 30 2013, 09:13 PM
QUOTE(Scotti @ Jan 30 2013, 06:29 PM)
Here we go again. Blast Off
So. Are you saying it's NOT a good idea?
Mike Bellis
Jan 30 2013, 09:17 PM
You should have no problem unless you decide to weld on the fuel tank.
If you had an ECU, it should be removed from the car. As said, disconnect the battery.
Jeffs9146
Jan 31 2013, 12:48 AM
Make sure you disconect both the + and - of the battery!
If you have a CDI unit for the ignition I would disconect it from the ground also!
