QUOTE(tadink @ Jan 31 2013, 08:19 AM)
hi guys - thanks for all the comments - the 3/8" at least value is what I'm looking for.
In order to answer the question "how much space do I need so the tires won't rub on the inner fender well" - my camber setting will make a difference, as will the deflection of the tires under hard cornering, yes?
If I set up with 1/2" clearance between the tire and inner fender, will that be enough?
A picture below shows the offset / backspace of the wheels / tires I'm dealing with - the tape reads 7.5" from inner sidewall of the tire to the back of the wheel.
Click to view attachmentUPDATE: So, to answer my own question - I've put 2" spacers on wheels with 7.5" backspace - and now have a bit over 1/2" between the tire and
tub-wall. I said inner fender before which probably screwed up everyone's thinking - sorry 'bout that. Unless the tires deflect under heavy cornering or the body roll is significant, I think I'm ok now.
I think the answer is, you need about 5" or less of backspace to clear the body - I've got 7.5" - 2" = 5.5" now....I'll run this a bit and check for rubbing.
thanks for your thoughts -
td
