john_g
Jan 31 2013, 08:20 PM
Okay, I need Dr. Evil and the other tranny gurus here to chime in. My current teener has only been in my possession for 6 months. I was going to replace the transmission fluid tomorrow because I have no idea how long the PO had the old oil in there, or what he had in there. Since it's 39 years old, I was wondering about the wisdom of having a hot flush done to clean out all the old oil and crud. What say all? Waste of money, or good way to start?
By the way, it currently shifts okay - some grinding if I shift into second too fast, but I know that that's not unusual for a 901.
scotty b
Jan 31 2013, 08:37 PM
That title might get the wrong kind of attention John
draganc
Jan 31 2013, 08:46 PM
make sure you can unscrew the filler plug before you drain the fluid!
Mark Henry
Jan 31 2013, 08:57 PM
QUOTE(john_g @ Jan 31 2013, 09:20 PM)
What exactly is a Hot tranny flush? I know the 5-minute oil change shops have killed a lot of engines with there so called BS engine flush.
And your tranny grinds into 2nd because the dog teeth and syncro band is worn out.
Mike Bellis
Jan 31 2013, 09:01 PM
QUOTE(Mark Henry @ Jan 31 2013, 06:57 PM)
Dr Evil
Jan 31 2013, 09:02 PM
Just change the oil. No magic, no fancy stuff. If there is tar in there, you will not get it out without splitting the case. You dont need to worry as the crap stays at the bottom since there is no pump.
ThePaintedMan
Jan 31 2013, 09:04 PM
Similar to a
straight flush.... but with extra parts.
Still beats four of a kind.
I don't know what a hot flush means, never heard of it. I say just change the fluid first. If you still have shifting problems, as mentioned by others, its probably mechanical (synchros).
bandjoey
Jan 31 2013, 09:31 PM
And don't forget.....regular old Dino Fluid...No Synthetic Fluid
Ask the experts and several recent threads on tranny fluid here
john_g
Jan 31 2013, 10:00 PM
Thanks - that's what I kind of thought, and don't worry about the type of fluid - conventional GL-5 w/o the LSD additives.
Mark Henry
Jan 31 2013, 10:15 PM
QUOTE(john_g @ Jan 31 2013, 11:00 PM)
02loftsmoor
Jan 31 2013, 10:46 PM
I was woundering about that
QUOTE(kg6dxn @ Jan 31 2013, 09:01 PM)
vw505
Feb 1 2013, 08:21 AM
What about changing it after a short time in te highway, just to make it flow out a bit faster.
Dr Evil
Feb 1 2013, 08:36 AM
Did I stutter???
"Just change the oil. No magic, no fancy stuff. If there is tar in there, you will not get it out without splitting the case. You dont need to worry as the crap stays at the bottom since there is no pump."
You can do that, but it is not going to do you much good and then you will be working with hot exhaust, hot oil, hot tranz, etc. That is a loss of productivity
vw505
Feb 1 2013, 11:13 AM
Good point.
yeahmag
Feb 1 2013, 12:42 PM
I can't stop giggling every time I see this topic...
76-914
Feb 1 2013, 06:41 PM
A "hot flush" is also known as a "courtesy flush" and is employed when sitting in the stall next to someone after a spicy diner.
flippa
Feb 1 2013, 07:37 PM
QUOTE(scotty b @ Jan 31 2013, 06:37 PM)
QUOTE(kg6dxn @ Jan 31 2013, 07:01 PM)
[img]
QUOTE(yeahmag @ Feb 1 2013, 10:42 AM)
I was a little scared to open this thread. With this title, it sounds like it belongs in the Sandbox.
Steve
Feb 1 2013, 07:44 PM
It's not any worse than the Doc's tranny clinic!! There's a bunch of people lining up in another thread to go to Canada to get there trannys checked out by the doctor. There making a big party out of it!!
