took her out for about a 8 mile drive tonight! I can't believe how much better the shifting is when you add a little lube to the joints! Shifts great. Accelerates great. Right parking brake adjustment was grabbing a little and driver's headlight needs dialed more to the center. Both headlights could stand to go higher. The dims are terribly dim. I don't know if I got my wiring wrong on the headlights? Also, the dimmer switch doesn't always go back to brights from the dim setting but I can hear the switch clicking when I try to switch it back to brights. I thought my fuel pump relay was not working from a month ago until I read a post today talking about the fuel pump only kicking on for 1-1.5 seconds when the ignition is first turned on. Back when I was commisioning the fuel system I never heard the fuel pump coming on and thought something was wrong with the circuit so I had installed a jumper in place of the fuel relay. After reading the post today I pulled my jumper wire and reinstalled the relay and walla! the fuel pump kicks on for a short cycle then turns off and the the engine stars and runs like it is supposed to do! I am soo happy. I will try to get the wheels aligned tomorrow if one of multiple shops is available tomorrow.
