QUOTE(David J @ Feb 1 2013, 02:02 PM)
I'd like to run 2" spacers on my front 89 Carrera hubs to fill out the front wheel wells a little more. It has 1" spacers now. I have 100mm studs.
Two questions:
Will ANY year 2" 944 spacer fit and center properly? Are 944 spacers different front/rear?
Does moving the tire further out from the ball joint/strut pivot point introduce additional stress into steering/suspension forces because of the lengthened moment arm?
I would think it would at least some i know its hard on bearings. I have been running 15X9 wheels on the front and back with know spacers with no rubbing. I just got some 17x9 wheels that are offset 2" back they don't rub the tub but they don't fill up the fender unless I use at least a 2" spacer
