If I use the jack points for my hydraulic jack (I'm jacking up the front end), where do I place the jack stands? Or... am I supposed to use another location for the hydraulic lift and use the jack points for the stands?
Tom_T
Feb 1 2013, 02:54 PM
Various jacking points - I'd use the doughnuts for jackstands & jack at another in the pic below, but you can pick best spots for what work you need to do & what clearance you need from that work.
under the right and left a-arms under the front trunk is good Gary
john_g
Feb 1 2013, 04:17 PM
Thanks, guys. I put it on the front torsion bar mounts (front circles in the diagram) and that worked great - then put the jacks on the regular jack points. Appreciate the help!!
