start at the bleeder closest to the MC. End at the bleeder farthest from the MC.
Other way around.
That "limey" up top is a typo.
You can "edit" your posts you know...
No I did not bench bleed the MC. I installed it dry
Not a problem really.
I thought the power bleeder would do magic.
It should really... OK, let's go through a check list:
1. Bleed furthest to shortest distance.
2. Tap lines and calipers with a plastic mallet or the wooden handle of a standard hammer while you bleed.
3. Adjust the pedal clearance/master cylinder rod.
4. Make sure the venting clearance is adjusted to .004"
5. Get a decent pedal and bed the pads.
6. Bed the pads again.
7. Bed the pads again and drive the car.
What happens "VERY OFTEN" (as in, almost 100% of the time) with a new caliper rebuild is this; the new seals are aggressively pulling the pistons back off the pads and rotors. Even a small amount will cause a soft pedal feel. As you bed the pads, you will heat up the calipers and the seals and they will break in. As the seals brake in, your pedal will begin to come back up.
Follow this procedure:
http://www.pmbperformance.com/bedin.html
