raynekat
Jun 3 2015, 02:09 AM
Lookin' good Mats.
I like the stripes with the Martini on the angle (middle one).
It will look great whatever you choose.
Keep up the great work.
falcor75
Jun 9 2015, 06:35 AM
Click to view attachment sorry for spamming almost the same pics but I'm just soo really pleased with how the stripes are turning out on the car...
Jun 9 2015, 06:54 AM
I like the stripes a lot.
EdwardBlume
Jun 9 2015, 07:15 AM
Dig the stripes. Very Martini!
falcor75
Jun 10 2015, 10:25 PM
Got an hour in the garage last night and got the old crank seal pulled out, measured the crank axial play with 3x0,34 mm schims in place and got 0,1-0,11 mm of play so that should be ok. Put in a new seal and torqued everything up.
I know the pressure plate looks crap but its just surface rust, both clutch and pressure plate only have a few thousand miles on them according to the receipts I got with the car.
thieuster
Jun 10 2015, 11:40 PM
Familiar sight! That's what I was looking at only a few weeks back. Have a good look at the flywheel.
BTW, I like the look of the braided hoses/sleeves over the thick wire on the background! Looks classy.
About the Martini striping: are you going to add the word Martini as well, or will you keep it like this? I would have considered adding the word, but when I look at the car 'as is', I am not so sure. The stripe logo is so iconic!
Menno
falcor75
Jun 11 2015, 12:44 AM
QUOTE(thieuster @ Jun 11 2015, 07:40 AM)
Menno
Yes I understand what you mean about the stripes, without the "Martini" logo its a very nice clean look. I wont add the logo right away as I kinda like it like this...dont want to rush and do something I regret.
This weekend I will hopefully finish putting the last stripes onto the engine lid aswell and then I can call that finished...for now. The goal is to have the engine back in the car by the end of the month and then start laying out the new ecu-harness.
falcor75
Jun 17 2015, 04:13 AM
Click to view attachment While torquing the inner nut with the rear sway arm in the horizontal position I just had to see if I had clearance with the 7x15 Cookiecutter and my 195-55-15 Nankang NS-2R tires and it seems to fit perfectly.
Click to view attachment Mmmmm.....gooold...
falcor75
Jun 26 2015, 12:50 PM
thieuster
Jun 26 2015, 12:53 PM
Looks fantastic! Keep posting these pics
Menno
gereed75
Jun 26 2015, 02:46 PM
really really nice build, Has that techno clean look going on.
falcor75
Jul 4 2015, 03:59 AM
Click to view attachment New battery holder lasercut, bent and welded up. Still unsure where to position the battery tho. Either the stock location or lower down on the passenger firewall.
Any suggestions?
barefoot
Jul 4 2015, 06:55 AM
With that height for your battery box, you may have to mount it much lower to be able to remove the battery, stock boxes much lower side walls.
Cairo94507
Jul 4 2015, 07:05 AM
If not in the stock location, may not be possible given the height of your battery, then the lower in the car the better. Car is looking very nice BTW.
arkitect
Jul 4 2015, 09:33 AM
QUOTE(falcor75 @ Jun 26 2015, 11:50 AM)
Mats,
What type of carbs are you using? Looks similar to the Weber IDF's but velocity stack top is different.
Dave
falcor75
Jul 4 2015, 11:47 AM
Dave: they're not carbs they're IDF pattern throttle bodies with injector ports (the round holes visible below the stacks) The stacks themselves will eventually be switched to taller full radii stacks.
914_teener
Jul 4 2015, 12:07 PM
Great thread and great work.
I was wondering that myself.
Looks like crankfire and ITB's What are you going to use? Microsquirt or was it already set up when you got the car.
Can you tell us about the induction system and ignition you plan on using?
falcor75
Jul 4 2015, 01:51 PM
I'm using a crank trigger and minicam sync from Mario @ thedubshop.net
He also sells the ITB's I have but I bought mine from the UK.
For fuel and spark I will be using 4 LS2 coils and a set of 350 cc Bosch injectors from a Saab 9-5 Aero.
All this will be driven by a swedish developed EFI system called Maxxecu, its kinda like Megasquirt but a but more "coherent" if that makes any sense....not alot of addons needed instead its all included in one package. Onboard wideband, E85 ready, bluetooth built-in etc. (
http://www.maxxtuning.eu/maxxecu/ )
Future wise the goal is to build a new 2276 longblock with around 10:1 compression running E85. The whole fuel system has been replaced using Chris's stainless lines and E85 compatible Gates hoses.
falcor75
Jul 5 2015, 01:06 PM
Well today I installed the Tangerine shift adjuster and the shift rods. Since I've never really driven my car much I dont remember how it should feel, Shifts are a bit notchy and stiff but at least I can find all the gears.
falcor75
Jul 9 2015, 02:48 PM
New sparkplugs going in.
ECU in place
Battery in place
and then....there's the wiring......Yay!
Getting the dash top in place and putting the plastic nuts in place is a dream job...not.
Got some Vintage Gold plastidip on the remaining Cookies aswell. Thinking of trading my set of 3 Fuchs for a set of BBS RS or Mahles.
falcor75
Jul 10 2015, 11:40 AM
Scott S
Jul 10 2015, 12:13 PM
Very cool!! You are making me miss my old car!
thieuster
Jul 10 2015, 01:56 PM
QUOTE(falcor75 @ Jul 10 2015, 07:40 PM)
Wow, great! Tell me more about the plastidip thing. Difficult? AFAIK, it's reversable without negative consequenses. Am I correct?
Menno
falcor75
Jul 10 2015, 02:14 PM
No the plastidip is quite easy.
Degrease your wheels and mask off any area you dont want to paint.
First layer goes on very very thin, allow it to dry for 5-10 minutes.
Second layer goes on normally thick, it wont cover everything yet.
Again let dry for about 5 minutes.
Third layer should cover the base surface completely, fourth layer goes on pretty much just after the third has dried alittle. Remove the masking while the paint is wet (just be carefull) There's plenty of youtube videos showing the process. The paint will peel off easily if you're not happy with it, just find an edge and pull.
falcor75
Jul 29 2015, 11:02 AM
CRAP!
ok....so how bad is a wobbly exhaust stud on the #3 cylinder?
Engine out, apart and repair bad or buy a new head bad?
Kinda lost my momentum when I noticed this earlier.....
DavidSweden
Jul 29 2015, 11:21 AM
QUOTE(falcor75 @ Jul 29 2015, 09:02 AM)
CRAP!
Mats,
Your car looks great. I am in Gothenburg so I will look forward to having a good look at it some time in the future.
I am not sure what your last post means have you a bad thread on the exhaust stud?
I had this problem with one of the exhaust studs on my 912, I the hole welded, bored out and a helicoil installed it was like new and it didn't cost an arm and a leg
falcor75
Jul 29 2015, 11:47 AM
QUOTE(DavidSweden @ Jul 29 2015, 07:21 PM)
CRAP!
Mats,
You are welcome up here anytime if you want to have a look before I get it drivable, wont be till next year I can drive it tho... I'm 90 km's north of Gbg.
DavidSweden
Jul 29 2015, 11:52 AM
QUOTE(falcor75 @ Jul 29 2015, 09:47 AM)
CRAP!
Mats,
Thanks for the invitation, I would like to come by. I have time this week up until sunday, does that work for you?
falcor75
Jul 30 2015, 12:31 AM
After sleeping on the issie I've decided to finish all the ECU wiring before I pull the engine to get the exhaust stud fixed. That way pulling the engine will feel like a bit of a reward for finishing the wiring.... (yeah I'm wierd like that....)
Dave_Darling
Jul 30 2015, 08:49 AM
Probably the easiest solution would be to drill and tap for an oversize exhaust stud. There are 8/9 mm ones, and I think 8/10 mm ones as well. I'd bet that Mittlemotor carries them.
--DD
falcor75
Jul 30 2015, 11:44 AM
QUOTE(Dave_Darling @ Jul 30 2015, 04:49 PM)
--DD
Yes that will work, I'll just have to get the engine out and take the head off and get it done somewhere. Might get the heads flowmeasured while its out and have them both checked out.
falcor75
Jul 31 2015, 12:48 PM
QUOTE(DavidSweden @ Jul 29 2015, 07:52 PM)
CRAP!
Mats,
I had a visit from David today and there was I think almost two hours of 914 talk. I think he liked what I've done so far.
falcor75
Aug 8 2015, 03:05 PM
Today I pretty much finished up running the lines for the oilcooler and got to see the front end assembled for the first time. The bottom valance is kinda screwed up from being patched a few times but it'll do for now. Eventually I'll get a replacement one.
I also got some adapters for the ITB's, they'll let me use any IDF style air filter.
Also got the LS2 coils and made a bracket for them.
raynekat
Aug 8 2015, 06:26 PM
Looking really good there....
falcor75
Aug 9 2015, 07:32 AM
QUOTE(raynekat @ Aug 9 2015, 02:26 AM)
tHANKS
falcor75
Oct 7 2015, 03:54 AM
ECU mounted
Injector connectors
Engine harness routing
TPS connector
Wires wires and more wires....
WB O2 connector.
914forme
Oct 7 2015, 08:31 AM
Wow excellent work on that wiring harness!!!
falcor75
Oct 7 2015, 10:17 PM
Thanks
phillstek
Oct 7 2015, 11:21 PM
Nice build, man! I really like your vision for the car and the way you’re putting it all together. You should be well pleased with yourself.
thieuster
Oct 7 2015, 11:37 PM
Looks stunning! Keep posting this sort of pics! I really like 'em.
Menno
mrfourteen
Oct 8 2015, 08:26 PM
Was the 914 meet at Niklas Ekström home near Malmo?
He has some nice rolling stock.
falcor75
Oct 8 2015, 10:15 PM
That's correct, he's got a nice little aircooled and watercooled fleet.
mrfourteen
Oct 9 2015, 10:42 AM
I have a similar build to yours in process.
http://www.914world.com/bbs2/index.php?act...=0#entry2215168QUOTE(falcor75 @ Oct 8 2015, 09:15 PM)
falcor75
Oct 9 2015, 10:59 AM
QUOTE(mrfourteen @ Oct 9 2015, 06:42 PM)
I know, I'm subscribed to your thread. Yours looks awsome!
falcor75
Dec 24 2015, 09:59 AM
Merry Christmas!
thieuster
Dec 24 2015, 10:14 AM
Classy, very classy.
I have nothing to match that - only perhaps that I wish you all a Merry Christmas from a blowtorch hot (!) part of Europe. No need for winter tires!
Menno
DavidSweden
Dec 24 2015, 11:14 AM
Looks good Mats, when will you fire it up?
Maybe I could come over and take a closer look if you are around over christmas and the New year.
David
falcor75
Dec 26 2015, 10:56 AM
Houston, we have cranking rpm...
Got some work done today. Pulled the intakes off, removed the plugs and checked the plug gaps. All good. Proceeded to mount the oil filter, fill the engine with oil.
Then I built a remote start switch and hooked it up. *drumroll* It cranks!
Nice with a built-in oscilloscope in the tuning software.
falcor75
Dec 30 2015, 10:54 AM
Oil pressure is up.
And today I also verified that I have spark on all four cylinders and that my timing light was dead on arrival. Waiting for new intake gaskets before I can button everything up again.
Oh and the engine harness was finished today. Wired up the E85 flexfuel sensor and
cut and tucked the last remaining spare input/output wires.
falcor75
Jan 17 2016, 11:10 AM
https://youtu.be/8FGpixyAc0wIts alive!
Granted firing it up revealed a few issues to be solved.
1. The new hi torque starter doesnt disengage quick enough, you can hear the slight whine in the beginning of the video till it disengages.
2. Turning the key off doesnt kill the engine, it keeps running and I have to kill it via the laptop interface to the ecu. I'm not sure why this happens.
Click to view attachment This is how I've hooked up the ecu, switched power from the post on the relay board to a separate relay that controls the power to the ECU.
3. Third issue is an oil leak from the left side valve cover. Suck having to pull the heat exchanger down to get access and fix it. Do I need to drain the oil before removing the valve cover?
