While I'm waiting for the motor to be done I'm fixing small issues...
The light weight front hood kit I bought from Camp914 has never been working properly, the struts were too weak to hold the hood up so I finally got tired of it and set to fixing it.
Moving the hinge bracket to this location gives it a much better angle to hold the hood up. Drilled new holes and mounted the bracket with M5 countersunk screws and nyloc nuts.
Tadaa! No more shamefull broomshaft to hold the hood up.
Another thing thats been bugging me is the brake pedal feel. I suspected I hadnt gotten all the air out of the brake pressure valve.
One 12 inch steel braided brake hose with male M10x1 in each end later and I can bleed the valve easily with two M10 bleed nipples on it, remount it on the firewall, reattach the hardlines and then bleed the rear calipers as normal. For apparent reasons I havnt driven the car yet but the pedal feels firmer.
195/55-15 on a 7x15 rim is a bit wide for the front trunk board to fit in place.
Spare wheel from a 944 will have to do.
And a small side project for my garage as SWD didnt want it in the livingroom.
