bradtho
Feb 2 2013, 03:56 PM
I'm trying to get my struts out. They're early style (pinch bolt, not the wedge bolt). Bolt is out. PB Blaster applied, tried separating the 2 sides of the pinch, but the ball joint won't let go.
ball joint still attached to the control arm.
am I missing something? suggestions? tips/tricks?
r_towle
Feb 2 2013, 04:23 PM
if you are replacing the ball joint, get a ball joint fork tool and use the shock to get it out.
Its pinch in there, so removing the stress by unbolting the front and rear of the a-arm helps sometimes.
Torch and alot of heat also works...with the fork.
rich
DBCooper
Feb 2 2013, 05:06 PM
We call them "pickle forks." I don't know why, probably funny to someone somewhere sometime, and it stuck.
Eric_Shea
Feb 2 2013, 05:19 PM
If you think the insert is good, take it out.
Then use heat and a pickle fork. They're fairly inexpensive at your local ChinaFreight.
bradtho
Feb 2 2013, 05:35 PM
heat (and a lot of leverage) did the trick. thanks for the suggestion.
