I keep flip flopping on selling my 914..and now it's becomming more evident that it's time for a change.. Off to 911 territory I believe.
So, For sale, 1973 914-4
This car started out from the factory as a base model black 1.7 in 1973. It was repainted at one point in yellow.
Engine:
-2143 cc type 4, recently rebuilt. I have put probably 16,000 miles on the engine since I built it, and 220 hours or so. It has run flawlessly the whole time. Most of these miles were freeway miles.
- 96mm AApistons and cylinders
- rebuilt and ported heads with stainless valves and chromoly retainers.
- 74mm crankshaft
- Schneider solid cam, new FEBI lifters, Chromoly pushrods, 911 adjuster, whole shebang.
- 40 IDF webers with Tangerine racing cable linkage. The carbs were recently jetted to be perfect, both in synch, and jetting.
- MSD-6AL and mallory unilite distributor.
- Kerry hunter header, and magnaflow muffler. Sounds awesome on the road.
Engine bay:
-Every surface was cleaned and painted satin black
-Custom engine bay sound pad was made. (Picture to come later of it installed)
- All wiring clean and spiral wrapped. Everything looks professional and proper.
-Stainless braided fuel lines/ -6 AN fittings throughout
The motor is extremely healthy, leaks no oil, and gets about 28mpg on the freeway. Oil changes were done with Brad Penn every 3,000 miles, and valves are done at 8,000 miles religiously.
Gearbox:
-Rebuilt about 8,000 miles ago using 3 new synchros and dog teeth, and 2 good used synchros and dogteeth.
- All bearings were checked for freeplay, and replaced as necessary
- Completely leak free
- All shift bushings were replaced with custom delrin bushings. This is one of the best shifting side shift 901's I've ever driven.
- Brand new Sachs clutch kit installed when gearbox was rebuilt.
-Brand new CV joints.
- Custom short throw shifter.
Brakes:
- 911 front struts with Volvo 240 series 4 piston calipers, with custom Coleman rotors and hub adapters. These things STOP fast.
*note, the picture of the brakes shows the 911 setup, I have since replaced everything with the volvo setup.
- Rebuilt 914 calipers on the rear, new pads and rotors
- new ATE 19mm MC
- New stainless lines all around
system has been completely flushed using ATE super blue.
The pedal feel and braking capacity is almost perfect for my taste, as well as many others who have driven the car
Suspension:
-Bilstein HD strusts/ shocks all around
- 200 LB rear springs, 22 MM front torsion bars
- 23 MM front sway bar, custom adjustable down links
-Elephant racing polybronze front bushings, custom fit Delrin rear bushings. Now squeak, and greasable.
- Lemforder turbo tie rods, and new ball joints
Interior:
- Rebuilt pedal cluster
- 914 AP carpet kit, along with the carpet on the firewall.
- FatMat installed throughout the car for sound deadening.
- Stock seats, but I also have corbeau forza's and race harnesses that will go with the car.
- Roll bar/ door bar setup. Custom fabbed. Acts as a harness bar and long stiffener.
- Custom center console with speakers, and CHT, oil temp/pressure gauge in the face.
- Custom gauges by Al Garcia, along with an Autometer monster tach. Incredibly accurate and smooth.
-Clutch tube was repaired and re-welded in.
- new clutch cable and throttle cable.
-All seals replaced on the Targa top, window, door, seals. Car does not leak at all when washed.
- Dash has been recovered in a high quality thick felt similar to that used on a 917, and the upper dash has been recovered in foam and vinyl.
- electric windshield washer pump/nozzles added
- manual Hirshmann antenna. great reception.
*note, the prototipo will not be included with the car. The car will be sold with a stock 914 wheel.
Wheels:
-Brand new VTO 15x7 minilites. These are almost an identical offset to cookie cutters, but a little farther offset. They look sweet IMO. again, these are brand new wheels..
Exterior/ Body:
This is the only let down on the entire car.
- The fenders were pulled by the previous owner, and the rear fenders were cut/ welded and spliced in to get more width. They are subtle, but look nice
- There is ZERO structural rust on the entire car.
There are a few places where the paint has bubbled, and surface rust has formed. I would say that the car needs a full respray, but other than that, the body is very straight. No sag anywhere.
- 914 AP front LE valance. Looks great on the car.
- Pilot foglights
This car has been my baby, and I regret to even having the thought to sell it at this point..but I can always get another 914 I suppose. Please keep in mind that I do not HAVE to sell the car; I am entertaining offers for it though.
I'm looking to see $13,500 for the car at this time. I may consider offers, but right now I'm firm at that price.
There is a lot more to list on the car, but that's all I've got in me right now. Literally every nut and bolt has been turned on the car. If anyone has a question, or would like more photos, please dont hesitate to ask.
I have autocross the car 4 times, and it would make an excellent weekend/ autocrosser. It handled exceptionally, and had plenty of power. It would also make an excellent daily driver if you didn't have very far to go. Even with the webers, it starts up every time, first try.
Thanks for looking, Ethan
