MrHyde
Feb 3 2013, 05:23 PM
I'm looking for the thin 32MM (1 1/4")wrench required to put turbo tie rod in the 914.. I had it all put in and then realized I forgot the spacers. Once that was put in my wrench just wont get in there. I could grind it down, but figured I'd see if I can get ahold of the proper tool instead. I can't seem to find one online so far.
Also looking for the socket to install the balljoint lock nut..
Thanks,
Mike
MrHyde
Feb 3 2013, 06:05 PM
Or... any suggestions on what to use instead of the proper Porsche tool ??
Mark Henry
Feb 3 2013, 08:31 PM
The ball joint tool I probably could make something that works.
The wrench I'd just go to Princess Auto, buy a cheap wrench and grind it down.
I'll look at this tomorrow (Monday) for you.
