nihil44
Feb 7 2013, 05:07 AM
The factory manual has instructions for removing the fuel filter for 75-76
1. remove mats and spare wheel from luggage compartment
2. remove cover with console and fuel pump
3. Pull fuel filter forward off of holder
What is the "holder" mentioned in 3. ?
I have looked in the usual places (PET, Haynes, etc) but can't find an illustration of the "holder"
I am converting my 74 to front fuel pump using the factory 75-76 mount (obtained from forum member - thanks) but don't want the square (cube shaped) fuel filter wandering around unrestrained under the fuel tank.
Does anybody have a photo or illustration?
Many thanks
David
SLITS
Feb 7 2013, 08:05 AM
76-914
Feb 7 2013, 08:30 AM
I don't think there is one. If there is I haven't seen it yet. And I've been in there several times.
TheCabinetmaker
Feb 7 2013, 10:45 AM
There is a bracket for the fuel filter. It looks like the early models that are mounted under the engine shelf.
nihil44
Feb 7 2013, 02:05 PM
Thanks Curt. Good stuff. Just what I needed.
JFJ914
Feb 7 2013, 03:18 PM
QUOTE(The Cabinetmaker @ Feb 7 2013, 11:45 AM)
I cut out the filter holder from the rear of the car and rewelded it in the front as shown.
Cap'n Krusty
Feb 7 2013, 03:27 PM
You don't say whether you're running a stock 4 with FI, or something else. That's a 911 pump, and it's not likely to produce the correct fuel pressure.
The Cap'n
