QUOTE(mboss @ Feb 20 2013, 02:36 PM)
Can you be a litle more specific of Marginally? am interested Thanks Mark
The trigger points in the distributor went bad, we were able to change them and it worked much better. It was then pulled off in favor of carburation and the fuel injection set up was never fully sorted. Not wanting to miss represent it I included the marginal proviso. That being said, the pressure regulator, pressure sensor, injectors, control unit, throttle switch, cold start valve & switch, air regulator, and deceleration valve, all seem to work.
