I purchased these back in 2001 after great frustration with my Ljet system. I installed these on my car, ran it for about 5 mins, then soon noticed a massive oil leak coming from under the car (one of my push rod tubes popped out). Turned the car off, then the next day a tree from my back yard fell and crushed my car. 10 years later with a new tub and a working Ljet system, it's time to part with these Webers.
I'm not sure what I have exactly. I can't tell if these are some Chinese knock off brand or are they from Italy? Directly under the fuel inlet, a stamp says "40 IDF 19 1B" on the other side it has a logo saying WEBER BREVETTATO, and to the right it says BOLOGNA. No where does it have a italy casting mark. I removed the top aircleaner half, to try to retrieve some numbers, but none seen. The bottom throttle plate has a number 76 stamped onto it.
There seems to have some sort of idle screw missing, circled in red
So what do you think these carbs, intakes and throttle linkage bundle is worth?
