QUOTE(euro911 @ Feb 12 2013, 10:07 PM)
They mount on the far ends of firewall, just below the rear window. You'll need to remove the back pad to install them. Once the back pad is off, you'll see the 'wells' the 'reels' mount in.
The threaded holes in the B pillars are for the 'hoops' the belts runs through so the belts run across your shoulders
The threaded holes in the longs near the back of the seats are where the other end of the belts secure.
Looked for some pix, this is all I could find quickly
Click to view attachmentWow! Thanks so much. I knew that was the case but I just could not confirm it. I think someone just took a number of short cuts on this car. If you could not tell from the picture, this was a very unsafe condition. Thanks for the response.
