highbinder400
Feb 13 2013, 08:48 PM
my 1970 914-4 oem brake master cyl has 2 electic ial attachments,,, replacement has only one elect connection ...what do i connect to what ??/ gary
914Sixer
Feb 13 2013, 09:25 PM
Two things, use the old one off you master cylinder. Make sure you swap the O ring from the new one to the old sender. Or you can simply wrap the end of the brown wire with tape and wrap it back. Plug the other wire in and you are ready to go.
rick 918-S
Mar 29 2013, 11:44 PM
I met Gary the other day. He stopped over to Area51Werks. (my garage)
He mentioned he owned his 1970 914 since like 1972. He stated he went to replace the master cylinder and discovered a 20mm master cylinder. He swears this is the original part. Anyone ever seen a 20mm master cylinder as an original part? I told him it should have had a 17mm.
Oh, BTW Gary:
914Sixer
Mar 30 2013, 07:02 AM
I remember at one point people were using larger Mercedes Benz master cylinders. Not sure if this is one of them but that would be my best guess.
rudedude
Mar 30 2013, 08:04 AM
I met Gary last weekend at porsche swap meet and saw that 20mm cylinder also. I couldn't believe he lived up north that long and hadn't met Rick. I'm glad you 2 finally got together, its always nice to know another enthusiast.
bdstone914
Mar 30 2013, 09:03 AM
Are you sure it was a 20mm and not just a 20 stamped on the bottom? If so post some pictures.
rick 918-S
Mar 30 2013, 09:18 AM
I asked Gary to post a photo here but he is not technical. His eyes kind of glazed over when we started talking about computers. Maybe I can go over to his place with my camera.
