chasrolex69
Feb 15 2013, 04:23 PM
Howdy, My fog lights quit working last night, i checked and one wire had come loose on one of them. Will that effect both lights to not work? or do they run separate?
Thanks in advance
Mike Bellis
Feb 15 2013, 04:28 PM
The other one should still work. You should check your fuses as the loose wire may have blown it. If you do not find a blown fuse, spin the fuses in the holder to loosen any corrosion on the fuse.
