xsboost90
Nov 14 2004, 08:51 PM
ill go ahead and introduce myself as im a regular on rennlist and recently more on here. My name is dan(xsboost90) since i used to be big time into turbo mk3 supras. Got my first porsche a year ago-89 944 and after doing alot of work/paint etc..traded it for a 924s and a 76 914 2.0. Now im in the process of rebuilding from the ground up this car including cutting out some rust-not too bad someone had already done alot-PO owned a body shop- but missed some in the floor and fenders. I also purchased a motor which has already been totally rebuilt w/ very little milage and a cam from someone local who needed more-200hp 2.0 rat motor!!- for their project. Ill go ahead and start a thread and try to keep its progress posted for those who find these things handy. I also have a couple of pics of what i plan on it to look like in the next couple months when i paint it..yes im a jack of all trades so to speak. Thanks, stay tuned.
xsboost90
Nov 14 2004, 08:52 PM
last week..
xsboost90
Nov 14 2004, 08:53 PM
here is where i welded the fenders into the cowl....what rust?
mharrison
Nov 14 2004, 08:54 PM
Welcome to the board! I'll look forward to following your progress. (Maybe it will encourage me to move a little faster on mine!)
So, any plans to BOOST the 914?
xsboost90
i threw a "pull the motor out party" this saturday, it was...short lived as it took a half hour to pull the motor and six more to drink all the beer.
xsboost90
Nov 14 2004, 08:57 PM
now i have the rear suspension out and im going to weld up the rear floor section, strap the rear arms/ frame and rockers inside the car, and install some s2- yes 944 s2 springs in the rear as they are the same size diameter and factory 160lbs. I also have some 924s phone dials that when i drill the rear and w/ the adapters on the front-eventually 911 suspension up front- bolt right up 6" wheels.
this is what im planning on the car to look like eventually.
914GT
Nov 14 2004, 08:59 PM
My kind of party! I'd like to go where I can drink beer and watch somebody else work on cars for a change.
xsboost90
Nov 14 2004, 09:38 PM
i doubt itll ever get boosted..but we'll keep that option open.
brant
Nov 15 2004, 09:43 AM
Dan,
wow.. great looking car.
keep it up...
brant
aircooledboy
Nov 15 2004, 10:11 AM
kafermeister
Nov 15 2004, 12:33 PM
QUOTE(aircooledboy @ Nov 15 2004, 12:11 PM)
Never think for one second yours is "just" another progress thread. I think it is a lock that everybody's two favorite things about this place are: 1)instant access to an unbelievable amount of knowledge and experience 2) the chance to gain motivation and vicariously live through the projects of others by following their resto threads.
Remember though, there is no such thing as too many pics, but you will get your balls busted if you don't post enough.
Well said Chris. I
progress pics and stories. Can't have enough pics.
Dan, if you need any help, I'm in the area and could donate the occasional Saturday afternoon here and there. What part of Cincy are you located? You hang with any of the VW guys?
FWIW, I also own a white '76 2.0 (rolller)....for now. May be going to new owner when the facilities become available. Then I'll start on my Blau '75 Ca roller.
Rick Harris
SpecialK
Nov 15 2004, 12:38 PM
I like the idea of welding up the cowl to fender seam, hey it's not like the fenders are 'bolt-on'. Looks good, and eliminates one of the many "rust traps" so common on these cars.
I'm all for customizing and modifying these cars to suit. The only version IMO that would be worth keeping absolutely "stock" is an original -6.
That being said, what's up with that yellow one......
Aircooledboy is correct, PICS, PICS, and more PICS!
Kevin
Steve Thacker
Nov 15 2004, 12:40 PM
Welcome to the board! I'm up here in Columbus. Keep up the good work on the car, looks nice.
xsboost90
Nov 15 2004, 09:45 PM
ok, some more pics of the car and some stuff i got to go into it...eventually.
xsboost90
Nov 15 2004, 09:48 PM
my rebuilt 2.0 w/ scat cam, racing wires, stainless heat exchangers and lightened flywheel....
xsboost90
Nov 15 2004, 09:50 PM
phones? oh yeah!
Gint
Nov 15 2004, 10:22 PM
Welcome to the Club Dan.
Make a sig, put your name and a link to this this thread in it. Let me know if you need help
MattR
Nov 15 2004, 10:28 PM
Nice car! I like the wheels, Im running the same ones on my car.
Can we get some more pics of the poster girls?
xsboost90
Nov 17 2004, 08:55 PM
got the floor all cut out the other day and ready to patch up, not much rust, just at the rear corner of the firewall and floor.
xsboost90
Nov 17 2004, 08:57 PM
made a patch panel for the center and welded it all up, next step will be the sides and center below the linkage...should be fun.
xsboost90
Nov 17 2004, 08:59 PM
sprayed some rust preventer stuff all in the entire center section of the floor all the way down to the pedals, sprayed rock guard around the welds in the patch panel, and then undercoated the whole deal...should keep it from coming back for awhile..I also made some drain holes in the patch to let out any water that may find itself back inthere.
xsboost90
Nov 17 2004, 09:01 PM
and w/ the undercoat...cant wait till the whole bottom looks like this..
boosted
Nov 17 2004, 09:07 PM
Hey Xboost, remember you from rennlist....
Nice work...
xsboost90
Nov 19 2004, 11:17 PM
hey thanks! got my rear arms apart tonite and cleaned them up to spray. NExt to have the rear hubs drilled...
Bleyseng
Nov 19 2004, 11:37 PM
Nice pics and yes, ditch the crappy adapters and get the hubs drilled before they break.
Geoff
xsboost90
Nov 22 2004, 10:39 PM
getting there, got one more piece welded into the firewall, doing a piece at a time to get the shapes all correct. I just finished welding in the pieces around the linkage/fuel lines/throttle cable and clutch cable. I had to weld the end of the clutch tube back on as well...kinda broke off. Then after i weld each piece im using etch primer to the bare metal and then using rock guard to fill in and seal the gaps around the edges. THen im using rubberized under coating over that! Im also using a rust prohibiter on the inside of the panels to keep me from having to do this again..hopefully. I like overkill.
xsboost90
Nov 26 2004, 04:16 PM
more pics, the floor is DONE!!! on to the body and painting the engine bay!
type47fan
Nov 26 2004, 04:25 PM
Nice work, Dan
. At the rate you're goin', you'll have it done in no time!
Eric_Shea
Nov 26 2004, 04:35 PM
One shot shows the phones on the back and the next page has you needing the hubs drilled
Looks good so far
(Let me know if you decide to go with those hubs I've got.)
xsboost90
Nov 26 2004, 05:37 PM
i got three of the four adapters for five lug when i bought the car...i needed the other rear to put all four on..i decided to have the rear drilled- more clearance- and eventually ill switch the front to 911 stuff a bud of mine is selling.
xsboost90
Dec 2 2004, 11:56 AM
yeah! ordered my five lug rear hubs from eric shea yesterday and should have em soon!!! also getting some new bearings for xmas-thanks dad- and euro lenses for the front-thanks mom. I have a feeling the gf/ is getting me another momo wheel....that would be swweeeett.
Eric_Shea
Dec 2 2004, 12:52 PM
Very good idea. Adapters = bad
Goods are on the way! Thanks!!
xsboost90
Dec 4 2004, 10:53 AM
yeah got my hubs today~
Eric_Shea
Dec 4 2004, 11:58 AM
Glad they made it!
From looking at that Avatar picture... you may want to have Grandma get you some sway bars for Christmas
Keep me posted on the progress. Feel free to ask if you have any questions.
E.
xsboost90
Dec 9 2004, 09:07 PM
ok, more progress...got the firewall and engine compartment including the inside of the rollbar primed and painted black tonite..looks pretty good, got a couple of runs from the cold weather and my little crappy heater didnt keep the temp up but good enough for an engine compartment.
xsboost90
Dec 9 2004, 09:09 PM
even the mounts for the suspension are painted now..just need some undercoat.
xsboost90
Dec 26 2004, 09:56 PM
collectiing parts lately, heres my euro markers, and i have now some wheel bearings and some needed tools, just waiting for the negative digit weather to settle down after the holidays.
xsboost90
Dec 29 2004, 06:48 PM
update again...got my chrome ds mirror and rear sway support brakets. I think ill be in the garage in the next week welding, painting and trying to put my rear suspension back together. I may also be cutting up the quarter and welding in some 944 quarter flares to clear my slicks.
skline
Jan 1 2005, 11:42 AM
QUOTE (xsboost90 @ Dec 29 2004, 04:48 PM) |
update again...got my chrome ds mirror and rear sway support brakets. I think ill be in the garage in the next week welding, painting and trying to put my rear suspension back together. I may also be cutting up the quarter and welding in some 944 quarter flares to clear my slicks. |
That sounds interesting, please post pictures of the rear flares on the car. I always thought that would look cool. You are the first one I have heard of attempting it.
bryanthompson
Jan 1 2005, 12:47 PM
Wow, I can't wait to see what those flares look like! I made a photoshop of what it might look like back in the day, I'll look for the file.
good work
Trekkor
Jan 1 2005, 09:19 PM
I like what you have done. I too, will be watching the 944 flares.
Keep up the good work!
KT
xsboost90
Jan 1 2005, 09:43 PM
well, i had my bud cut the flares off of this car before he tows it off, they are now sitting in my garage w/ my pile-o-parts. After i get my swing arms welded up and its sitting on all four again, im going to put on my slicks and check clearance. Based on that, i will cut out the lip of the fender, weld in the flares, and weld the lip back in like factory. IF it clears-doubt it- then ill leave it be, but i dont see that..of course.
dan10101
Jan 2 2005, 12:01 AM
We will be watching the flare thing closely.
Andrew has been eyeballing my spare set of 944 rear quarter pannels sitting in the backyard. We did some measurements a few times and it is a possibility. Maybe have to put them on backwards due to the length of the pannels. We never got any further than that.
(if anyone else gets the bug, I'll let them go cheap...
Steve Thacker
Jan 2 2005, 05:42 AM
xsboost90
Jan 3 2005, 10:40 PM
got my braces for the rear arms finally today, alread have one installed. Not my best welding by i think itll work for a street car.
xsboost90
Jan 5 2005, 10:54 PM
got the second arm all welded up. Those little holes are hard to weld through. NExt comes the primer and the paint for them and then some installation. Maybe then i can see if my quarters will need to be stretched.
Stutgart46
Jan 6 2005, 08:14 AM
Keep the pics coming.
Are you still going with the 2 tone paint scheme?
jd74914
Jan 6 2005, 11:22 AM
Yeah. We need pics of the 944 flares on your car if you every get to that. I've been thinking about that for a while (I don't especially like the look of gt flares, or the cost) I've never seen an teener with them though.
Great work, and good luck
xsboost90
Jan 8 2005, 09:33 AM
ok so still working on the swing arms-may get them painted today- but i got them in primer and ready. I also ended up selling the mirror i just bought and buying a cool set of custom ones from the local street rod store. I like these much better than the chromey.
xsboost90
Jan 8 2005, 09:34 AM
heres my mirrors- manually operated no cables or anything, but they are adjustable and have little caps to cover the screws after you install everything.
